Deuceofspades
Experiencing weird bugs using vegas 8.0 with Raylight and mxf files on PC - windows XP pro.
Bug #1 - When rendering, the sound will no longer be synched to the image. When I then check my timeline I find it is , in deed out of whack. I close Vegas and reopen it and everything is back to normal. It has been doing this one time out of two.
Bug#2 - I am getting random sound SPIKES in the final rendered file. I play the quicktime file, all looks good and all of a sudden a loud ZEEEEK, very high pitched. When I check my timeline I cannot see a spike in my sound file. It must happen while rendering? My master mixer indicates the original project levels to a A-OK at the frame where the spikes occured in the rendered file.
Bug#3 - Cropping an event in Vegas caused major weird results. It seemed to work fine at first, but after I closed my project and repoened it a few days later none of my crops/pans worked. What I saw was a weird stretching of the image, like I had stretched it sideways, instead if a crop/pan to follow my black crow flying across the desert.
HAS ANYONE ELSE EXERIENCED THESE AND WHAT DID YOU DO ABOUT IT.
This is not promising.
