Raid & SSD Advice Wanted
Will_Red
Hi Guys,
We’re looking at investing a bit of money into hard drives & backups and I would just like to seek your opinions before we make a purchase.
We produce a low budget TV series and have done 3 series to date – currently working on our 4th, all has been edited in Adobe Premier Pro.
S1 was 3.12 TB (10x30min eps)
S2 was 7.26 TB (10x60min eps)
S3 was 6TB (10x60m)
So 16TB of data all up so far, and we expect S4 to about 10TB as we changed cameras (to an Fs5) /upped the bit rate as we are filming in (Slog).
Everything to date has been edited off either internal or external hard drives and speed has been marginal at best (especially when trying to re-edit versions of the final projects to sell overseas) so we are wanting to take the next step to either a Raid setup, SSD or a combination of both.
After doing some research this is what we are looking at – buying a Raid setup for S1,S2,S3 (16TB) setup as Raid 0 (with a cheaper large or couple of hard drives as a backup)
Either
WD 16TB My Book Pro Professional RAID Storage https://www.amazon.com/12TB-Book-Pr...ra-20&linkId=5adef0f8786b71c166b365bf9455560e
or
WD 16TB My Book Duo Desktop RAID External Hard Drive https://www.amazon.com/16TB-Desktop...rd_wg=0o3Wi&psc=1&refRID=JRHA58BF3N3J39YZV80R
We are using PC’s so it will be connected via USB3. This will hopefully be fast enough to do minor editing to old projects???
And then going forward we would look at purchasing a similar Raid setup for Season 4 editing, store the video files (majority of space required) on the Raid drive, and then put a 1TB SSD or similar in the computer, and when editing; have the project file, media cache, preview files etc. on the SSD and leave the footage linking through from the Raid drive.
What do you guys think/recommend? Is the speed a premiere project runs/ restricts your editing, controlled by the speed of transfer from the footage (in this case the Raid drive) or once loaded and setup, is it just the project and preview files etc (in this case the SSD drive) which will control the speed?
Open to any suggestions.
We also stumbled across this site which seems to have some bigger Raid setups on this site https://www.span.com/product/Synolo...416-SATA-HD-RAID-0-1-5-6~51093/spanstor=45997
Anyone purchased off here? We are based in New Zealand so are a bit limited over here as to where we can purchase from.
Am I right in assuming if we used 4 drives rather than 2 in a Raid 0 setup, we’ll get twice the speed, and twice the chance of something going wrong with the setup?
Thanks for your help.
RAID 0 is for hobbyists. Imagine if you lost your RAID 0 mid-stream, under deadline. Sure, you have your media backed up elsewhere but you would have to either repair or buy a new RAID, transfer the media back over, reconstruct and render out all of your CC, effects, titles, etc. The delay could be days or even weeks, depending on the complexity of the project and how you were backed up. My suggestion would be to buy a RAID 5 setup and make it twice as large as you think you will need. IMHO, it's not practical to keep non-current projects on your RAID, the RAID should only contain current projects being worked on. The rest need to be archived off line, which is a whole other subject and discussion. RAID 5 allows the RAID to rebuild itself in the event of a drive failure or data corruption. I was a staff producer at a production company that had ten editors, and we, as producers and preditors, often had delivery on 2-6 active projects at a time, each of which were in various stages with different editors. I can tell you I lost years off of my life from stress and generated many gray hairs over RAIDs that imploded or became corrupt at the worst possible moment, it happens. So if you plan for disaster, then when it strikes, it just becomes a slight time delay rather than a Titanic level slow death.
Thunderbolt 3 is the current best interface for most solutions but even if you go Thunderbolt 2, you can generate respectable throughput numbers of around 500-600 Mbps, with redundancy. Of course RAID 0 is faster, but you are flying without a net, which, as a producer and professional, is not a wise decision. Murphy's law loves to rear it's ugly head often when you are under deadline and have a client tapping their foot, waiting. We are in a similar situation and are going to probably buy this 20 TB Thunderbolt 2 RAID 5 https://eshop.macsales.com/shop/Thunderbolt/External-Drive/OWC/ThunderBay-4-RAID5 as it is large enough for us to keep one or two projects on-line. The remainder of our media is then backed up on two different bulk drives off-line. So we have four layers of redundnacy, two of them on-line, the RAID material and the rebuild capability of RAID 5, and two off-line. What we don't have is a viable off-line long term storage strategy as that involves streaming LTO solutions that we have not yet invested in. Drives are only viable for about 3-7 years so if you have material where it matters that it is archived for at least a decade or two, you need to explore LTO tape solutions.
RAID5 or RAID6 is about the lowest I would go right now and Thunderbolt 3 or 10gb network connection is what you should be doing. You can probably get away with a single 1gb connection to a decent network attached RAID box, but the extra overhead that a faster connection offers would be good.
I'd be looking into FreeNAS to build something with ZFS to handle disaster recovery or buy one from ixsystems as a FreeNAS mini https://www.ixsystems.com/freenas-mini/
No network switch, just a direct connect (crossover cable) to the back of the NAS.
I agree with Raid 5.
I would also say that depending on the size of your average project (assuming you only store current project on RAID), it could be worth looking into thunderbolt SSD RAIDs. Suuuuper fast, but more expensive. $2k for 4 x 1TB (4TB total). But blazing fast!
The downside of SSD, besides the price, is that if they fail, the data is not recoverable. However, RAID 5 and a back-up makes this a non-issue...with the incredible speed advantage.
A good 8+ spinning disk array makes the speed advantage over what most people are using for SSD raid no advantage. And you can buy larger than 1TB disks for $50 each so an 8+ disk array won't cost more, holds more data, and has similar speeds no matter how small the data chunks are or random/sequential ordering. With RAID6 and 8 disks you can lose at least 2 disks with little consequence and probably losing 3 disks is still recoverable. ZFS would give you anywhere from 1 to 3 lost disks (depending on ZFS level) in the same array. The problem with FreeNAS and TrueNAS is that I don't think there is a direct to Thunderbolt connection and definitely not a direct to USB3.1 connection since it is a computer with a bunch of drives. A little added expense to put in a 10GB network card (server side) and then get a Thunderbolt3 to 10GB interface or 10GB network card in your workstation. There might even be an LTO backup integration, but I'm not certain.
My low end FreeNAS server tested to minimum of 1tbps across the 8 disks, this was back when I built it and using small laptop speed drives. I've since upgraded to NAS level of drives but haven't checked the speed. The maximum of the original was around 5tbps. (Notice bits not bytes). And FreeNAS no longer takes a genius to get running, and a simple check box to add Media Composer compatibility (not tested by me yet) to the shares. Open source, free (software/OS), and runs on most things (including Virtual Box so you can test to see if you can do it). There is a Linux port but I forget the name, FreeNAS runs on FreeBSD Unix (some flavor).
