puredrifting
Major Contributor
Hi all:
I am hoping that some of you have some RAID 1 experience? I am setting up a P2 workflow for a documentary project and based upon reviews here and elsewhere, the CalDigit VR looks to be a contender. I would like the convenience and reliability of the RAID 1 workflow when downloading P2 cards to the drives.
In the past, I tried setting up a RAID 1 workflow using two physically separate drives of the same size and brand. I discovered that while the dumping portion of the operation went fine, when we would separate the two drives, wanting to send one of the drives to the editor and keeping one for safety, the separated drives would not boot correctly and were basically freaking out, looking for the other RAIDED drive. This was a few years ago, but I recall, we used Apple Drive Utility or some other third party software to set up the RAID 1. Is there some sort of formatting operation or option that is needed when you physically separate one RAID 1 volume from the other?
The CalDigit VR looks to be a great drive but I need a work flow that will allow me to dump all of the P2 cards to the two volumes, then I want to separate the volumes, one for backup and one to the editor. I contacted CalDigit and they told me that I am not allowed to switch out the drives on the CalDigit VR anyway, it voids the warranty and dark clouds of the Apocalypse will gather over our shoot. This sort of seems to negate the whole idea of the RAID 1 CalDigit VR workflow. I need a drive setup that I can setup as RAID 1, unload the drives, and then load new blank drives, format them and configure for RAID 1 again and do the same thing. My editor will need to take this RAID 1 formatted drive, mount it on his FCP system and edit away. Is this a strange workflow? What I have been doing instead of this is bringing two separate drives to shoots, dumping all of the cards to one drive, then cloning the cards in the breaks in between. This is stressful and non-automatic, it requires concentration and awareness of exactly what has happened to each P2 card. I can do that, but it requires either a P2 tech or a lot of my time and attention, which is tough as I am typically DPing and or producing the shoots as well.
I believe the CalDigit VR contains regular Hitachi SATA drives don't they? I cannot understand why, if I rotate the stock drives out with identical OEM drives from Other World Computing, it would void the warranty. The VR has easily removable drive trays. Why have removable drive trays if you cannot change out the drives? It seems to not make any sense.
Anyway,
1. Can you separate RAID 1 volumes on a hardware RAID 1 setup and use the two drives separately without the drives freaking out and looking for their RAID mate?
2. Has anyone used the CalDigit VR and successfully changed out new raw, SATA drives?
Thank you!
Dan Brockett
Anyway,
Thank you!
Dan Brockett
