Quick release plates on tripods are proprietary?
I have a 503 head and I need to buy another head. I want to be able to take my cams off of one head and quickly place on another head. So if I have a 503 and have the Bogen quick release plate on my cam then can I only place that on other Bogen heads or does it fit on other heads like Sachlter and Miller?
Re: Quick release plates on tripods are proprietar
Bogen plates are as you suspect, incompatable with Sachlter and Miller heads, and vice versa.
Cross brand use is not going to happen.
[quote author=pookie link=board=Links;num=1108531790;start=0#2 date=02/15/05 at 22:00:00]Bogen plates are as you suspect, incompatable with Sachlter and Miller heads, and vice versa.
Cross brand use is not going to happen.[/quote]
Thank you Mr. Pookie :)
All quick release plates are also not compatible within a manufacturer. I've used some Bogen heads that wouldn’t take the quick release from the 503... One of them was the 516, but I didn’t expect it to...
