quick question about lens adaptors
DBoz699
for the DVX100....they have the widelens .7 or .8 widelens...then theres the anamorphic adaptor...whats the difference between the widelens and the anamorphic adapter? i thougth they do the same thing...make everything more spread out...someone clarify this for me cuz im not very technical with this kind of stuff.
At the same distance away from what you are filming, wide angle lens will increase the area/persective that will be seen, because of the curvature of the lens.
An anamorphic adapter is designed to get the highest quality 16:9 display by optically squishing what you see onto a full frame. (Initially, the the frame will look like it has been squeezed vertically, but the image is suppose to stretch itself out when displayed on a wide-screen tv.
Anamorphic (description)
Wide angle (description)
Good article about Anamorphic lenses
Here is an exaggerated comparison of the effects of what a wider angle lens will do, when a picture is taken at the same distance.
(These are not my own pictures)
(This one has a much wider angle lens than the one above, ... almost fisheye-ish)
[anyone correct me if I'm wrong]
