Gary Sconce
I am building 6 light stands for Aftershock Studios feature shoot this spring. Here is the first light stand done:
The goals are: 1) to be built super cheap... 2) to be sturdy 3) to rise up from 3' to 13' adjustable height of light 4) to have a 4' span on the boom.
As they will be transported in a trailer, they only need to shed the booms and then get stacked.
On this one I lucked out and had an extra mike stand for the adjustable boom arm. Others will just use pins and sliding tubing as will this one's vertical riser.
Just 1/2" and 3/4" electrical conduit and a bicycle seat clamp for the boom lock. The vertical tube is 5' with a 4 1/2' internal tube that can rise. With the 4' addition of the boom vertically raised, it will hit the 13' I need. YAY!
I figure they will cost around $15 each less lights. Here is another shot. See the square stock welded directly on the nose of the boom tube. This allows stage C clamps to be used for versatility.
Notice the square washer on the back of the boom that will hold a counterweight. The tubes will velcro down all the wiring for grip safety on set. One of the stands will have three castors with brake locks on it.
Gary
Gary
