questions: water mark, and MANIPULATING IMAGE
007liron
Hey guys,
I'm working on a new project and have two questions you might be able to help with:
1. Anybody know how to add a water-mark sign to a film in FCP 5? (for copyright protection, when I'm sedning it to people).
2. I have a short shot (1.5 sec.) that I want to manipulate in Photoshop. So I was thinking I would just divide it to single frames, work on each in PS and then upload it back to FCP.
Sounds right?
If so, is there a more efficient, non annoying way to divide the shot into frames other than using the 'freeze frame' option?
Appreciate your help guys,
Liron.
1. Just put the water mark above all the other video layers and adjust the size and opacity until it looks like what you want. If you can also apply a watermark using Compressor if, for example, you have a full rez QT file that you want to compress into web-size w/a water mark for someone to download.
2. Set your In and Out points then, File->Export->QT Converstion->Image Sequence.
-A
