Denis Haineault
Hi,
I'm getting close to snapping and ordering some lights, but would like a few clarifications about gels and color temperature options:
- I understand that CTB gels will absorb a good amount of light, but I'm unclear if CTO gels are just as bad. My guess is that loss of light does occur, but not as much ??
- Assuming CTO gels aren't as bad as CTB for light loss, does it make sense to have only daylight balanced bulbs, and use CTO gels whenever you need 3200'ish temperatures? I mean that in terms of ease and flexibility gear-wise.
- Assuming you have total control of the light sources, and you want to (say) make your picture a bit warmer, is there an advantage to using gel on lights instead of modifying the temperature setting in camera? Is it just a matter of personal preference?
- I know that in reality, color temperatures vary greatly when it comes to actual daylight, gel manufacturers, bulbs of all kinds, etc. but assuming "perfect" conditions, and assuming all the options are available to you, is there an order for using gels vs using different bulbs, vs adjusting temperature in camera? Does one yield better result over another, or does it end up being the same whatever you choose?
thanks,
Denis
thanks,
Denis
