Questions About Brevis Flip
Tim Naylor
Is there anyone with first hand experience with the new BRevis Flip that can answer the following:
1) How is it with dust sealing? This was a problem/deal breaker with an earlier iteration I owned.
2) How is the compatibility with an SG Pro. I own a non-flipped Sg Pro. I don't want to wait for Lord knows how long it'll be until there "optimized" achromat will be available.
3) How's the E 2 E with an HVX and EX 1
4) Does Cinevate plan for an "optimized" achromat or is the current one great with E 2 E?
5) How well and practical is the x/y adjustment for centering the image?
I can only afford one more adaptor for the time being and torn between the lex and brevis. I had sold my earlier lex because of E2E issues which seem to have been solved. But an ideal situation would be a Flip that's compatible for my SG as well without compromising its great E 2 E.
Shed some light somebody.
Tim
Tim,
I don't know I'll try to look at this tonight or tomorrow.
In my tests with a Rev2 it worked well on the HVX (still needed a "mid" focus" ) but was best at full SLR image size. My test frame showed it getting softer when i zoomed into academy. I may recheck that though to make sure it wasn't a mistake.
From what I can figure from Wayne it should be the same with a Rev3.
Now Wayne put a new condensor lens in his SGUnit to adapt to his flip. He told me he could sell that for less than $100. This may improve the results with a Brevis flip as well, but who knows for sure.
Its an easy thing to switch
An alternative concept would also be to get Wayne's flip and use it also on a Brevis, but that might be more trouble because it really needs a very positive connection since its not on rails.
Vignetting isn't bad as its pretty centered, but it has the same soft corner problems as the other adapters using old achromats. It looks fair @ 5.6 and fine @ f8. Gets quite soft when you zoom in beyond full SLR.
Dennis says he's working on it and it will be soon.
I didn't look too hard because it seemed fine on both HVX and Letus right out of the box. In fact I paid no attention to it. I guess i should. It does have the same type adjustment as the original Brevis with allen screws.
That's the best i can do today.
lenny levy
