I'm pretty new to the film making world and am preparing for my first shoot with a small cast. I have no prior background in film, but have been learning as much as I could in the past year. I've bought and watched through the Hollywood Camera Work series which was quite informative, but had a few questions about optimizing takes and shot lists.
Question 1: If I'm shooting different angles of a conversation, should I shoot each angle all the way through? For example, from HCW, I get a sense that the more angles you have, the easier it is on the life of the editor. For a basic two person conversation, it seems like a basic/technical approach might be:
1. Master two-shot
2. Over the Shoulder Medium Person #1
3. OTS Close Up #1
4. OTS Medium Person #2
5. OTS CU #2
Quick Diagram:
If the scene is two minutes and averaging 3-4 takes per shot, then shooting the scene all the way though I would assume around 30-40 minutes to shoot (a 20:1 shoot to scene ratio). Is that a reasonable ratio?
Would it be better to try to break the scene down so I don't shoot the entire scene with all the angles? For example, saving the OTS medium for earlier in the scene and the OTS CU for the latter half.
This post on a breakdown of a scene from Goodfellas describes a possible 7 setups for 1/4 of a page of script and seems to advise to shoot all the way through the scene. 3-4 takes x 7 setups x 20 second scene = ~9 minutes or 27:1 shoot to scene ratio.
I found this thread pretty useful: Making a shot list . Good general info here and recommendations for HCW/Script Supervising and Film Continuity which I will check out.
Question 2: Do I keep the camera rolling between takes? I know that traditionally slates are used to help organize scenes for the editor (as well as possibly help time sync with the slate clap), but wouldn't pausing the record between takes automatically create clips for just that take?
Question 3: It seems like to make editing easier, the actors should talk a little bit slower than normal (or at least pause a tad bit more). Is there any way to ask an actor to do this have an adverse affect on their performance (especially beginners/amateurs)? Or do I just try my best in post?
Related threads
Directors that shoot a high number of takes
From this, I get a sense that with amateur or beginning actors, directors typically favor less takes as the actor's performance will likely degrade from fatigue.
Seamlessly edit dialogue together between takes
Room tone is definitely great advice and there was minor discussion of whether or not asking amateur actors to not overlap dialogue affects their performance.
Thanks in advance for any feedback!
1. Master two-shot
3. OTS Close Up #1
5. OTS CU #2
Quick Diagram:
Related threads
