I am having trouble figuring out why I'm getting low levels with the following setup: an AT4053b mic about 12" from the subject to a sounddevices MM-1 to a DR-100MKii. The DR-100MKii allows XLR line input and that's what I've set the device to (plugging in the XLR cable for the line out from the MM-1 to the input on the DR-100MKii) When I increase the preamp gain on the MM-1 to the max (66) about the highest levels I'm getting is -18 (monitored on the DR-100MKii) so I suspect that I'm doing something wrong. My understanding is that I should target peaks of -6 to -12. I have the limiter switch set to on on the MM-1 and the high-pass filter switch set to 80 Hz as from reading this forum that seems to be the recommended setup. I'm new to audio so hopefully it's something easy that I'm doing wrong. Thanks.
