Gohanto
I did location and post sound on a 48 hour film this last weekend (first time since I bought a MixPre I've used it). Levels turned out fine, but on some door slams I clipped. I set levels to -16 dBFS at the camera with the 1kHz tone (we tried running 2 cables and tone to -12 and -20, although for some reason the cam's 2nd input wouldn't work, so we split the difference)
Doing some more investigating...
MixPre's limiters are initially set to +18dBu (adjustable by screwdriver so there doesn't seem to be a reliable way to set the limiters to a known value, especially with them recessed and hard to see)
And I've seen pretty common advice here to just set the 1kHz tone to -12dBFS in other threads, but that would clip @ the camera before even hitting the limiter.
So...
1. Is there a good way to set the limiter on the MixPre for a camera setting of -12dBFS?
2. Or is there ever likely to be a problem recording to camera from the MixPre using -20dBFS? (I've heard this to be great with 24bit recording, but 16bit audio seems more of a split decision)
So...
