portlandbozz
my movie im shooting i need to do a 2 cam 2 mic run n gun shoot, indoor and outdoor. both cams and both mics are identical, 1 mic each cam exc. anyway, i want to eliminate what i can for best portability. i was thinkin of axing my field mixers. question is, will eliminating my mixers affect my audio at all? i have expensive mics (2-5k range) so i wasnt sure if the quality of the audio will change running each mic straight to the camera instead. will the audio be noisier? will it sound the same as running through the mixer to cam? ive only used mixers using these expensive mics and when i wasnt using mixers i was using 5-1k range mics. so this never became a problem for me. i was gonna have the channel audio volume set to the same on both cams for the mic. also, any phase/hum/other worldly stuff i should know about using two mics near each other? something i also never do. im just worried i will lose quality in audio from these mics doin the straight to cam. is this a good idea? or is it neccessary to use mixers using these types of expensive mics or any for that matter
