Question about Zoom H1
hellboy80
Does anybody have Zoom H1 audio recorder?
I bought it and I have this problem... If I want to monitor the sound via headphones I need to really pump up the volume of line out (otherwise the sound is very quiet) . This increases the noise (only in headphones). The recorded sound is clean, but the monitoring is practically useless (when I hear noise in headphones all the time, I cant be sure if its only in headphones or if I am actually recording the noise). Its possible to fix this problem? Buy better headphones?
BTW, I am using Rode NTG2 mic (with Shure A96F transformer which adapts XLR-type connector to the 3.5 mm input).
Don't go above 70 on the volume output. 80 at the most, because that's where noise starts becoming obvious.
Also, don't use intermediary values. Stick to full decimals (60-70-80, nothing in between because those are noisy).
If it's too quiet, buy a portable headphone amp.
Yeah, I really have not had that problem at all with my H1, and I've used it quite a bit (straight audio and audio for video), and have not had issues with the headphone output. What headphones are you using? If you need a lot more volume, maybe an external headphone amp is what you need. But I did record a classical concert last spring using the H1 as a bit-bucket; decent front-end mikes, simple Behringer mixer... ran the output of the H1 into the input of my Sony Walkman Pro for back-up-- No issues with noise not only in the recording, but throughout the chain (and I monitored at various points like the mixer phone output, Walkman phone output, and even checked at the H1 output), so I'm wondering if you have a defective unit? How long have you had it? Maybe you can still return it and swap it for a new one?
GJ
Hi
Just curious. H1 has AGC (Automatic Gain Control) have you played with it?
Good luck
The headphone noise isn't an AGC issue and I don't think he's got a defective unit. Mine's doing the same.
I also have a problem with low input volume... I was duscussing all these issues here:
http://www.dvinfo.net/forum/all-things-audio/511218-zoom-h1-noise-headphones.html#post1757293
Interesting, I didnt know that. Does this apply for input volume too?
The NTG-2, as well as other mics that supply their own phantom power via battery, have a noticeably lower volume/level output than mics that draw their phantom power externally.
I see. Maybe this will be the problem.
"The NTG-2, as well as other mics that supply their own phantom power via battery, have a noticeably lower volume/level output than mics that draw their phantom power externally"
-- Not to confuse anyone but technically and FYI, an internal battery does not supply "Phantom Power" and running a mic on Phantom Power, opposed to a battery, would not 'significantly' boost it's output level or dramatically reduce it's 'self-noise'. Furthermore, a mic's battery should normally be removed when using Phantom Power unless it is manually or internally switched.
