I was looking at what other audio people had to say. I have the FR-2LE field recorder, which records in stereo. Some say to plug in the mic with a Y-cable. Then turn up one of the mic trims so that normal volume of dialogue records at a level of 12-6. Then turn up the other mic trim, so only shouting and screaming reaches 12-6. Then I can choose the best of both tracks in post.
Others say that using a Y-cable is a mistake, cause it cuts the mic signal in half, thereby weakening the quality, and to just plug the mic into one of the channels instead, and remove the other channel in post. But if a Y-cable cuts the signal in half, then why use it that way?
