Question about tripods
rightfrog
Hi,
I'm starting a business creating 30-second advertisements for vertically mounted, 16x9, 42-inch plasma screens.  My plan is to shoot using a DVX-100A and the anamophic lens to get true 16x9 but mount the camera vertically (turning it on its side) so I can use the entire height of the screen.
My question is, is there a good, fluid-head tripod where the mounting bracket can swing up, making the camera go into portrait mode instead of the normal landscape?
I know that there are good tripods that do this for use in still photography, but they aren't made for moving the camera slowly to pan or tilt, rather they just lock the camera into place.
Any ideas?
Thanks in advance,
---Christian Remde
Re: Question about tripods
You'll definately need a photographers tripod head for heavier medium format cameras.
These heads allow photogs to quickly switch between portrait and landscape usually by the flip of a lever.
A ronford or weaver steadman head would do that. I just saw one of them on ebay. Not sure if they are still available. Not cheap though.
Thanks to everyone who commented...I think the Bogen elbow bracket is the way I'm going to go at first.
Thanks,
---Christian Remde
bogen also makes the 055A sticks that alows you to remove the center column and mount it at 90 degress
i just love cruising the bogen catalogs, both the video and the photo, all sorts of things you can use even if it isn't in the way they intended...
http://www.bhphotovideo.com/bnh/controller/home?O=WishList.jsp&A=details&Q=&sku=241139&is=REG
i found this little item, i kept thinking it would be nice to not have to keep taking the tripod plate for my 503 head off the camera whenever i wanted to mount it somewhere else.
so i found the above item, it lets you take the 503 plate (it actually comes with another 501/503 plate, and lets you screw it down to anything and has 1/4 20 and 3/8 so you can mount it to another tripod but i plan on using it as a swiss army knife that will sort of fit the gap between a tripod and a hi hat.
matthew
