Here is a sample of an article i read (my question follow the article):
AUDIO COMPRESSION FOR THE WEB
UPDATE – June, 2010
Recently, I was talking with the tech support folks at Aphex, who make high-end audio gear for network and broadcast work. They told me that MP3 files are optimized for a maximum audio level of -6 dB, while AAC files are optimized for a maximum audio level of 0 dB.
Since much of the audio work that I do gets compressed into both formats, I’ve lowered my audio levels a bit so that they are peaking between -6 and -4.5 dB.
My audio still sounds good and I get nice clean results when compressing to MP3 files.
(For the record, almost all my encoding is the spoken word, as opposed to music, and I use a data rate of 56 kbpsfor MP3 compression of mono audio files.)
NORMALIZING
Based on this, when I normalize clips, I’m now normalizing to -4.5 dB. I also use the same level settings when using the Limiter filter in Soundtrack Pro.
I WAS WONDERING. DOES THE AUTHOR MEAN YOU SHOULD DO THE FINAL EDITING OF THE VIDEO IN MP3 OR DOES HE MEANS WE COULD KEEP THE ORIGINAL WAV FORMAT AND THAT THE WEB COMPRESS THE WAV FILE IN MP3?
FOR BETTER RESULTS, WHAT SHOULD WE DO ?
THANKS IN ADVANCE,
DELEUZ3
UPDATE – June, 2010
NORMALIZING
THANKS IN ADVANCE,
DELEUZ3
