question about a battery 9v with a negative connector that is square
deleuze3
Hi,
i'm not sure where to ask my question, but i always had good results with this awsome community so i'll give it a try.
My father use a battery 8v for a smoke detector (or another important device for the house). But we found out that the battery was not like any other 9v battery.
9 volts batteries has on top of the battery : 1 positive connector and 1 negative connector with octoganal/hexagonal shape.
The 9 volt battery of my father is a 9v but with a 1 negative connector with a square shape.
I looked on the net to find a 9v battery like this with no results.
Do you know what it is ?
Thanks in advance if you have any thoughts,
Have a great day
I have never seen any other kind of 9V battery - but the 4 or 8 sided connector that is always on the flying lead version on the battery top can sometimes be mated with a different type on the battery. This alternative type sometimes consists of two spring steel connectors that are parallel to each other, with open ends. the round connector pops into this gap securley. There's no other type I'm aware of.
yes i confiemd with my father that its octogonal finally, i'll try to find online. Its less common. Thanks Paul !
Maybe it’s a language barrier but I don’t understand what you’re asking. 9v batteries have a circle and octagon terminals as long as I can remember and traditional fire detectors use these batteries. Are you saying you fire detector doesn’t take a traditional 9v battery?
Hi Peter, well the most common 9v batteries nowadays i found on the internet have a circle and hexagon terminals it seems.
(at first i thought my father had a battery with a circle and a square terminals, but i found out it was an octogon)
My father has a fire detector that use a 9v battery with a circle and octogon terminals and i found some on the internet so he can buy one.
Thanks for your reading and comment, have a good day!
i thought that hexagonal were more common in general. Where do you live, by the way, Peter, you live in usa?
Polygon if you like I haven’t counted the sides. But it’s not crucial to the fit. I still don’t understand your question
i see. Well, at first i thought my father had a battery with a circle and a square and i didnt find any on the web. my question was : does anyone on dvxuser know about a 9v battery with a circle and a square. i was wondering if dvxuser could help to find such a battery to help my father.
After. i realize my father's battery 9v was rather a circle and an octogon. I found some on internet to buy (but they are less common than battery with a circle and an hexagon).
Now my father will probably buy a 9v battery with circle and octogon.
Question answered.
Thanks everyone.
Question answered.
Thanks everyone.
Like I said before it doesn't matter the shape because it is expandable. Do you realize the male connector that goes into that socket is round. So why would it matter whether it was a hexagon or and octagon? Any 9 volt battery would work otherwise they'd have a special classification.
