The Irish TRex
My second question is...
I am using Premiere 6.02 and I've noticed on some DVD players my 24p footage shakes a bit. Not on every DVD player...but I'd say about 60% of them. And not when I simply export to tape it's always lookin good. I know about the whole strobing thing with 24p footage but this isnt the case I don't think cause my camera is static and there it doesn't happen on all DVD players. My non-24p footage played well on every DVD player so i've ruled out the discs and burner being the problem.
I've read a load of topics and the only thing I've noticed that I didn't do that most suggest when exporting to DVD is I didn't use variable bit rate (I used constant at 7456 mbps) and one person noted something about m and n frames needing to be at 3 and 12 respectively. Would changing this (or other things in the mpeg encoding process) make the difference?
I shot this on my DVX 100B
Edited in Premiere 6.02
Exported it using my Ligos MPEG encoder plug-in.
Burned it using DVDit-pro onto a couple different brands of discs.
Thanks so much!
Hopefully someone can help...
James
Thanks so much!
James
