digitalinnovations
Does anyone have any (even quasi-firm) numbers on the output from a single 4' Quasar tube? I cannot seem to find any. I'd also be curious as to the output of a fixed 5600k tube and their Crossfade tubes? The fixed is a 30W and the Crossfades are 50W but typically with a color adjustable source you lose, what, 50% of the output? Is this true with these as well? If so then the output would be less (25W vs 30W).
One other thing I am curious about, if anyone has had any firsthand experience with the Crossfade tubes, is how precisely you can actually dial in that temp. Based on the pictures it looks like they would be more a "ballpark" number and that could be tricky when using multiple tubes to get them all to match. But maybe there are stops/clicks?
Hopefully someone here can help with some info. Thanks!
