stevedocmaker
I am setting up a workflow for a project that will be using h.264 footage from a Canon 5d. I know I must convert these files to a more FCP-friendly format for editing. I've read that there is little or no quality loss when converting to ProRes422, and that this is an FCP-friendly format, so this seems like a good choice. The way I see it have have two options.
I can edit straight from these files, color grade, render and export to delivery. Pretty simple, but the ProRes422 are rather large files (let's assume disc space is not an issue).
I can also add another step of creating proxy files (PrRes422proxy), edit and color grade with these, then reconnect to the standard ProRes422 files, render and deliver. More time consuming but the proxy files are quite a bit smaller.
I do not have much experience working with ProRes files in FCP. Will the larger, standard files bog my system down? Is there any advantage to working with proxy files other than file size (I don't anticipate needing to work on a laptop)?
