protools LE record sound
mumin
Hello I'm using protools LE and mbox 2 I wanted to hook up a mic and record my voice onto the computer when i press record . I get a message saying " problem detected with audio clock, check that your clock source and sample rate is correct" Can you guys help me what I need to change?? I played with sample rate but nothing.
I haven't had that particular error (mine are usually way less helpful), but you may want to check that you have the analogue input selected, rather than the SPDIF.
Go to setup and then Hardware and then set the Clock Source to Internal and see if that helps you. Good luck.
I would ask this in the Le section of the DUC (Digidesign Users conference) you more likely to get an answer.
Do you have anything connected to the digital ins? Many devices will not fully shut down the digital port and if connected to an interface will send a whacko signal that the interface "thinks: is a digital clock.
