I shot a commercial with a panasonic dvx100b . Used the same tape to shoot in both , 60i and 24p modes. I would shoot several takes in 60i , then after that switch to 24p .
Right now all our work machines have crapped out firewire ports and I have lost the original tape . So when I did capture the tape, it was on a video toaster 3 using the normal NTSC 29.97 setting for DV video.
I decided to use Adobe Premiere 1.5 since I haven't upgraded to the CS3 version yet on my machine. Used the panasonic settings for 24p .
Put footage on timeline, exported a few clips as AVI's to take into AE CS3 . Exported as dv 24p advanced ....
Problem is . . . I didn't shoot it as 24pA . So am I exporting the clips right? Or does it just need to be 29.97 ?
Right now the spot is basically finished just bad blur/stuttery video .
Also to note . . . when I import the clips into AE CS3 , the interpretation for the footage is set to 23.976 fps, 3:2 Removal (WWSWW - 24P Advance) . Does it need to be removing 3:2 pulldown already? Since I'm still taking the clips into post after and editing. Just a bit confused on all this.
I have read numerous web-sites, boards, and just can't piece together an answer for myself . It just looks horrible on a HDTV and even computer of course.
