Prop guns
TimCollins
Alright so I've got a production down the road and the last thing I need to figure out is what I'm gonna do about the gun shot scenes...
So I know you can use non-firing prop guns and add the muzzle flashes and gunshot effects in post... but what's the consensus on using blank firing guns that actually make the gunshot noise and flash themselves?
I would much rather use something that makes the noise and flash itself because that would look far more believable and really make it easier for me in post.
But is this safe? I've heard they can hurt you if you're too close but none of the gunshots in my film are from point blank.
What is you guys' experience with this?
Thanks in advance.
-Tim
I got a rather nice looking pellet gun that I use for scenes that require a handgun. It's made of metal and the slide/hammer moves when you fire it. Since it's CO2 as well, you get a fair bit of kick when firing it. I find that, combined with the weight makes it seems quite realistic.
Here's a quick test shot I did to try and add in a muzzle flash in post. Keep in mind it was a quick test lol, and also my first time ever trying something like this. But I think it turned out alright, and if I had spent a little more time on lighting/sound etc, I would have been quite pleased with it.
http://www.youtube.com/watch?v=2uLF4-3Fhxw
Definitely a safer alternative to using blank firing guns though. (Although, I would have liked to use them, they're frowned upon quite a bit up here in Canada... and VERY hard to get a hold of if you're an indy film maker)
Hmm I'll have to see why it says unavailable... As far as the sound goes, you're a lot better off adding the sound in post anyways, chances are the sound you get on location will be tough to get right if you want to have all your other sound levels to sound good. That's my opinion anyways, not to say it can't be done.
I've been on the site in your link before, unfortunately for me are the words written right under the description of the gun...
Here are some photos of the pellet gun I picked up at an army surplus store:
Here is a picture of the real beretta it's modelled after:
That one looks nice.
About the post production, that's always an option but I'm not really experienced with adding in digital effects like muzzle flashes and such, pretty much all I've done is simple, not special effect editing. So I'd really hate to shoot a good flick and have the climax be soiled by cheesed out, unrealistic effects.
I'll just test both ways before hand and see which I like better. I agree though, the blank gun would be very loud which could be a problem. Aside from capturing the sound, you also don't want the neighbors to think people are getting shot next door!
Thanks for your help and that sucks that they won't ship to Canada...
Yeah, I know what you're saying, I'm worried about the same thing... A feature I'm going to be working on soon calls for some effects that I'm not really comfortable doing myself yet, so if I can't find a good after effects artist or a good way to do the effects without cgi, I guess I'll just need to cram in lots of AE practice in the mean time haha.
Good luck on your search though!
If you dare, please use extreme care with your setups. The time spent to learn to do the effects in post would be cheap compared to an incident on set.
Actor Jon-Erik Hexum died when he put a stage gun loaded with blanks to his head and pulled the trigger.
Actor Brandon Lee died when the gun firing blanks had the lead part of the bullet lodged in the barrel.
Actor Ken Holiday Shot and killed by a blank firing gun.
Just to name a few
Check out this website: www.moviegunservices.com/mgs_weapontypes.htm
btown, can you send me your footage or take a little more of the gun (perhaps a couple of close ups)? Ide like to take a crack at adding some muzzle flares and sound.
Sure, so you want the footage before any post work was done to it then?
I could probably take a few shots tomorrow of me just firing the gun off if you wanted to play with that a little bit
Okay, let's talk about a few things....
You have to differentiate between guns DESIGNED to fire ONLY blanks, and REAL guns just LOADED with blanks.
A gun DESIGNED to fire ONLY blanks is going to have a very hard time killing anybody. Why? Because the barrels are solid. The gases (the 'flash') eject usually out of the top of the barrel, not out the front. So it's simply not possible for the gun to fire any kind of projectile.
I believe most, if not all, of the cases mentioned earlier involved people using REAL guns that were simply LOADED with blanks. This can be extremely dangerous. In the one case, where the person put the gun to his head, the force of the blast coming out of the barrel fractured his skull and sent a piece of bone into his brain.
In the case of Brandon Lee, again a REAL gun was used. For a closeup shot, the gun was loaded with REAL bullets which had been modified -- the slug was taken off, the casing emptied of gunpowder, and the slug re-attached. The bullets were then put into the gun (which was a revolver) so that the bullets could be clearly seen in the closeup shot. Then, for the actual shooting, the modified bullets were removed and blanks put in their place. But what they failed to notice was that the slug had been loose on one of the modified bullets, and remained in the chamber when the bullet was taken out. When a blank fired behind that slug, it effectively became a real bullet.
These things cannot happen with guns which are DESIGNED to shoot ONLY blanks. Not to say they aren't somewhat dangerous. But not nearly as potentially deadly as real guns loaded with blanks.
BUT by the same token, guns DESIGNED to shoot ONLY blanks aren't going to give you the muzzle flash you seem to want so much -- because they don't allow the hot gases to go out through the front of the barrel. They go out through the top or side of the barrel instead. Which, of course, won't look right.
The BEST thing to do is get a gun designed to shoot only blanks, but don't put blanks in it. Add the flash and 'bang' in post. You say adding a sound in editing is beyond your capabilities? Then you really need someone else doing the editing. Even I can do a muzzle flash and 'bang'. (BTW, I got the 'bang' by recording audio of the prop gun shooting a blank in a controlled environment.)
It's really not that hard, and it's a WHOLE lot safer.
btown, you just scored BIG TIME. To get Matt to do that for you is an incredible honor. Don't let it pass. :beer:
I think there's alot to be said for whether it's a gun specifically designed for blanks (closed barrel) or a real gun loaded with blanks.
I have no use for a gun beyond using it as a prop for this film, therefore I would use a closed barrel blank gun for safety reasons as mentioned by chapelgrovefilms.
The post is still a route I'm going to look into. I had an old friend whose taken editing courses who was going to help me edit on his Mac G5 but I took too long to get the project rolling and he's in Colorado now (I'm in Georgia). And as I can't really afford to fly there or fly him here, it looks like it's up to me to get the editing done, which is fine. I just want to make sure I don't mess up the shootout sequences as I've never edited any of those before.
Hopefully it works out, thanks for your responses.
