Projection help please...
skankib
I've shot some interviews for a presentation at work. Now, they gonna be doing a powerpoint presentation and at the end showing the interviews. What is the best format to export final edited interviews as? I'm also not 100% sure whether they're going to run them straight off their computer or a disk yet.
Any suggestions?
:a:
Re: Projection help please...
sorry forget to mention that all this will be playing through a projector onto a screen...
:a:
When you go to export your interviews, use Quicktime Conversion. Choose Quicktime Movie and under settings choose either, multimedia CD-ROM or even internet high-band width. (Not sure if I have those names down perfectly) After that. Go into Power Point and import them.
P.S. If projecting on a LCD projector, you will probably need to set the computer's resolution that is outputting the image to 1024x768. If that doesn't work, hit fn. F7 a couple times to toggle the LCD/CRT mode.
Hope this helps out!
