"Professional Haze" - Anybody here used this?
Shawn Murphy
..or any of their other products? They have quite an impressive client list (probably for their other products), but was wondering if anybody has ever used the stuff in a can?
http://citcfx.com/docs/fantasy.pdf
http://citcfx.com/products/index.htm
http://citcfx.com/main/clients.htm
FANTASY FX™ Haze in a Can
100010 (horizontal spray)
100011 (Auto - vertical spray)
100015 (Poof packaging for Halloween)
The Spray Smoke in A Can called Fantasy FX is used for Steam effects, Haze Effects, or Smoke Effects just by changing the lighting angle when using this product.
Fantasy FX Smoke In A Can is readily available and easy to use for magical special effects that create enhanced moods, dreamy sequences, beams of light from strong lighting sources, reflections from beams off of a mirror ball
and many more uses.
Used in theatre, movies, and plays, this easy to use product is so common that it is in every grips, property or special effects truck as a standby for those emergency ideas that need to be done right away. One can lasts a long time
and can be used over and over again.
II. HAZARDOUS INGREDIENTS​
Chemical Names:​
Medicinal Grade Mineral Oil (Proprietary formula)​
Seems like the same stuff so I'd probably get similar results.. would you happen to have any footage from a scene you shot with this? Did the actors give any feedback or comments about working with it?
Thx!
