Procedure or method FCP > Flash 8
arno
What is de best method to get the best (!) results to get a Flash 8 film.
I have a 720 25pn project in my timeline (FCP 5.1.4). What to do?
Greetings Arno
You can go straight from the timeline. Export using QT conversion and change the settings to FLV. Of course, this will only work if you have Flash or a Flash plug in inside your QT library. If you have a compression ap that does FLV (like Sorrenson) then I believe you have to export your timeline to a QT file then drop that into the ap. Just a guess though, I've never used anything to make FLV files other than Flash.
