sean guerrero
having problems with firestore fs4 hd 100. wont run time code into hard drive in hd mode
I get rec/pause out to hard drive in hd record but no time code read. when camera is in tape mode the device will read dv when hdd mode is set to dv record on hard drive.
Ive seen a few problems similar to what im having here. anybody have suggestions?
Im using the hvx 200 p, settings are - on p2 menu other functions
1394 control - ext
1394 cmd select-rec-p
pc mode-1394-device
1080i
on fs4 hard drive settings are- record- normal
hdd mode-hd recorder
hd format-quicktime
setup-tc rec run
functions -sync
control-tapeless
nle final cut 6
1394 control - ext
pc mode-1394-device
1080i
hd format-quicktime
setup-tc rec run
functions -sync
control-tapeless
nle final cut 6
