Hi all! Happy Xmas!
I wanted to know if anyone has found these problems with filters. I have a Chrosziel Matte Box and I also bought a graduated ND, a polarizer and a Black Promist, all made by Tiffen. The first thing I noticed was that when using the Blck Promist in Wide Angle I could see so clearly the "grain" of the filter :-( If I want to use this filter I have to pull the zoom in order to blur the grain and achieve the effect...
The other problem I have is that when pointing at the sun with the mattebox and filters in it I can see very clear on the monitor the objetive of the camera reflected on the filter.
I still have to do some tests removing the UV screw filter I put to the camera. If it helps anyone I have to say that if you use this kind of Uv filter screwed in you will get round squares in Wide Angle when editing on your computer. You know what I mean, don't you?
Thanks!
Thanks!
