Problems w/24p footage import
Lo007
I'm new to working with 24p footage, so thanks in advance for your understanding and patience. I have been scouring the boards/manuals for days now and haven't come up with any answers yet for my problem.
My specs: Mac G5 dual processor, OS 10.4.11, 2.5 GB RAM; Final Cut 6.0.2.
Footage was shot with HVX200, 720p24 setting. P2 content now exists on internal hard drive; kept folder structure perfectly intact when transferring from P2 cards. When I view P2 clips in Log and Transfer, metadata in FCP shows: format as 720p24, shooting rate as 24, video bitrate as 100 Mbits, Source as DVCPRO HD 720p60, pulldown as 2:3, Vid rate as 59.94.
If I have "Remove Advanced Pulldown and Duplicate Frames" checked in my Import Preferences, and I import a clip, I get these problems: (1) clip shows up as 23.98 fps, but the audio is out of sync. The audio seems to be playing faster than the video--it's slightly sped up. (2) the circle icon to the left of the clip name is half-colored, which indicates that the clip didn't fully import; (3) the clip seems to be missing a few frames. I can tell this because when I re-import it but deselect "Remove Advanced Pulldown..." I get a clip that's 10 frames longer with in-sync audio, and 59.94 fps.
Thinking Raylight might help, I downloaded the demo version. But when I scan the clips, the Raylight scan window shows clips as 59.94 even though I have selected "Remove Pulldown". (It also shows them as 1280x720 which is odd). And when I view the Raylight clips in FCP browser, they are 59.94 fps. I can't seem to get them to come in at 23.97.
Since my film was shot in 720p24, I thought I would be editing in a 24p sequence, and that this was the best way to do things. But I can't get my footage to import properly that way. Any advice? Ideas? What would be the disadvantage to just editing the whole thing in a 59.94 sequence? I'm nervous about doing this because from all my reading it seems like if you shoot in 24p you should edit in 24p. Again, my understanding of 24p is somewhat rudimentary so thanks for any explanations...
My project is film-festival bound and will be output to tape in HD format.
Thanks so much for any help!!!
Ok... I'm not super familiar with the HVX... but it would seem to me that the 24p mode is 29.97 with a 2.3 cadence. The 2.3 cadence is NOT advanced cadence. You cannot use FCP to remove this cadence.
You need Cinema Tools to remove it -- take it in and cancel out of the database open dialog box. Then use the Reverse Telecine process.
That will remove the cadence.
If you really wanted it at 23.98 you should have maybe shot at 24pA mode??
CaptM
It's a little confusing- the compressor codec is displayed at 720p60 even if the actual frame rate is 24p. When you drop a clip into a completely empty sequence and have FCP adjust the sequence settings to match the clip you should see. Check the sequence settings- frame rate should be 23.98, codec 720p60. That's normal.
Noah
Noah
Thanks so much for everyone's input! So, if I drop a clip into an empty sequence and have FCP adust the settings, I get a sequence with 960x720 frame size, 59.94 editing timebase, DVCPRO HD 720p60 compressor. Yet again, my data columns in my Log and Transfer window show for that same clip: format as 720p24, shooting rate as 24, video bitrate as 100 Mbits, Source as DVCPRO HD 720p60, pulldown as 2:3, Vid rate as 59.94. ??
Post some screenshots of the clips in your bin with settings and the sequence with its sequence settings- that would help us help you.
Noah
Thanks for your help! I'm trying to put these pdf's of: 1) log and transfer window, 2) bin window, 3) sequence settings after I've put clip into my sequence.
into this post but am having difficulty doing so. Can you view the attachments here? Sorry!
View attachment log_transfer.pdf
View attachment bin_window.pdf
View attachment sequence_settings.pdf
Noah
Hi Noah,
