Problems capturing timelapse
dr_stupid
I shot some footage in interval record mode, 30p. I can't seem to capture it properly in Vegas. I go through the DV capture process and as I'm watching, it counts off all the frames that it is capturing for the full duration of the time lapse clip. But when I go to play the captured file back, it only contains the 15 frames from that first 0.5 seconds of recording. Everything else has mysteriously disappeared.
Any help would be much appreciated! Thanks,
--Pete
Is scene detection turned off? Turned on you would end up with a bunch of short clips. Turned off you'll get one large clip.
There is a setting for the minimum length it will capture. The minimum is well above that.5 seconds.
Unfortunately, I don't have Vegas here with me, so I can't tell you exactly where it is. But you'll find it, or someone else will jump in with an "Oh, yeah. That."
Dan
