problems backing up g-drive to g-raid
ralph2
I recently backed up my 250g g-drive to my 500g g-raid. I did it the mechanized way as stated in the manual as opposed to the drop and drag method.
It seems everything got backed up but when I open a sequence it shows most of my project as normal image icons but some of the material has a red-line through it and says media offline. Yet when I watch it the media that is suppose to be there is there. I did a test compression with some of the material that says it's offline and the image that was meant to be there got compressed fine.
Should I just ignore what the machine says as far as media files being offline or is a way to correct it? Or should I backup everything again? And if so does that mean I have to erase what is on the G-Raid now or will it recognize the new backup and delete what is necessary itself? Should I do it by drop and drag?
And if so how do I consolidate some fo the files that went mostly to my g-drive but some went to my Imac harddrive?
Please help if you can. Thanks.
Right click on the clips and Reconnect Media. That will clear it up.
And I'd drag and drop for sure. I have no idea what you mean by "the mechanized way" nor what manual that's in. Can you clarify?
