EP2005
im exporting my project out of Vegas as an .avi with NTSC DV Widescreen 24p (2-3-3-2 pulldown).
I've changed the setting to an uncompressed format with the frame size using the project settings and the pixel aspect ratio at 1.2121.
When I go to import that render into After Effects, After Effects changes the pixel aspect ratio to 0.90 and the fps to 23.98.
If I render the file in Vegas using a compression like NTSC DV Widescreen, After Effects has no problems with it, but I feel like im loosing quality if i go in and out of After Effects with a compression used.
Why is my uncompressed files giving me a problem?
