I just bought a Varizoom VZROCKPZFI from another production team. The zoom works fine, but the Focus and Iris controls only work if I press very hard on the plug. Additionally, there is about 1mm of plug sticking out of the jack even when it's fully inserted and I put pressure on it.
Has anyone else experienced this problem, and do you have any suggestions about a solution?
I read the PDF instructions, and in accordance with those I have the Focus switch on the camera on A (Auto). I've made sure that the plastic housing on the plugs isn't interfering with the insertion (the fit is awkward).
It seems like there's a physical connection problem between the Iris/Focus jack on the HVX and the plug on the VZ.
Thanks for any help in this matter.
