Problem with Render Que
fu-pow
I'm having a problem using the Render Que in 6.5 pro. When I try to render out it says "The directory for the output module no longer exists."
Well I go to my computer and the "directory" it's still there.
When I use "export" it works fine. Problem is that I want to export as an OMF file to Avid Express Pro which isn't an option under Export but is in the Render Que.
Has anyone else had this problem?
oneinfiniteloop said:
I've never tried to render out an OMF, but you might want to try a different directory to see what happens.
By directory I assume it is another drive? I have 2 internal and one external harddrive.
