Problem with my project settings.
DecadenceFilms
Hi guys,
My footage is 1080 25p (Pal). Obviously I do not have the option of putting my project settings to 1080 25p, only 24p.
When I start a new timeline FCP asks me if I want to change the project settings to match the footage, to which I obviously answer yes.
However. It does not appear to work properly. The aspect ratio changes, I'm not sure of the technical term for it, but essentially it pushes the footage in at the sides and up at the top, giving a squished and elongated look.
2 questions:
1.How do I alter my project settings to prevent this from happening in the future?
and
2. What is the quickest or easiest way to correct the problem on an already edited timeline?
Cheers guys.
Rick.
OK. I've worked out that you need to set the project settings to 1080 50i.
Could someone help me with the second question?
IE What is the quickest or easiest way to correct the problem on an already edited timeline?
Cheers, Rick.
I don't know much about the settings your messing with regarding PAL and what not. But to access the settings for an already edited timeline, you have the timeline selected and press command+0. That will bring up the settings for any selected timeline. Anything you change in there will change in the timeline. You can change individual settings or load sequence presets all together.
