Problem with mixing 2d and 3d in AE7
redfuse
Hi all,
I'm having a small problem with after effects 7.0, basically what I'm trying to do is to slide pictures over each other. Only, on one point of time picture A should be over picture B, and on the next point picture B should be over picture A (but then with about 20 pictures). Since layer order is not keyframeable, I tried to do it with 3d-layers. So I created a camera with almost infinite focal length, so that when I change the Z-position of layers they don't shift optically in the x and y direction. The problem I'm having now, is that when I use this '3d'-composition in another (2d)-comp, all the seperate layers in the 3d-comp shift, so I am assuming that it uses another camera to render the 3d-comp within the 2d comp than I am using within the 3d-comp, if that makes sense. Anyone an idea how to solve this? Also, if anyone knows another solution to changing layer order over time, that would also be great...
Thanks!
I already found the solution, I had the enable the little asterix next to the pre-comp so all transformations in that comp are collapsed...
