problem with anamorphic lens
  • Start date Start date
G
Guest
Guest
just finished my first shoot using the Panasonic 16:9 adaptor lens. Had a problem-- the small tightening screw stopped tightening! Apparently, the hole for it became stripped just under normal usage (we really didn't over tighten) Now, we cannot get the adaptor off the camera because the screw has to be tight to twist off the lens. If I send it in for repair, I would have to send the camera with it. I have tried sticking small bolts, screwdriver, etc. to try and hold the ring while I twist, but it's not working and I don't want to damage the hole anymore than it already is. I'm hoping this should STILL be under warranty so I also don't want to jeopardize that. Any suggestions out there or similar experiences?? Thanks.
