David W. Richardson
Chapelgrove Films
In the last 3 or so weeks, I've been encountering a problem when uploading to YouTube or Vimeo.
Mainly, every week I upload a video of the sermon from our church to YouTube. In the last few weeks when I do this, I tend to get the following error:
"An error has occurred while sending data over the network. Please check your network connection and try uploading again."
I clicked the link to "check your network connection". It asks if I'm using certain versions (or higher) of IE (with Silverlight enabled), Firefox or Chrome. I am using Firefox 47.0. It says "Firefox 4 or higher", so that should be fine. So I tell it that didn't fix my problem. Then it says "Try using Chrome incognito window or Firefox Private Browse to upload your video. This will temporarily disable browser extensions. Ad blocking extensions, for instance, are often responsible for these problems."
When I use Firefox Private Browsing, I can eventually get it to work -- although it takes several tries. But when it finally is uploading, it will multiple times fall back to a smaller percentage completed. For instance, it might get to, say, 81% complete, then suddenly go to 43% complete for no apparent reason. This makes uploads take a long time.
I tried IE (with Silverlight enabled), both 32-bit and 64-bit, and had the same problem.
I would chalk it up to some YouTube issue, but I get similar problems with Vimeo now.
I'd rather not use Chrome.
I had read somewhere that doing uploads over a wireless connection could cause this problem, and changing to a wired network connection would help. I'm on my desktop PC, but it does connect wirelessly. So I've just run a net cable from my PC to the router and disabled wireless on the PC -- same problem.
Is anyone having similar issues? Any suggestions?
BTW, I'm running Windows 7.
