Prob from AE --> FCP
Lemme start by saying that my footage was shot, and my FCP timeline is 24Pa, so my AE seetings are also at 24 fp...
I export the portion of my sequence I wish to work on in AE as a quicktime movie from FCP, then import into AE and do my magic.. I then add to a render cue, and render out using the DV/NTSC compression settings at best quality etc... However, once I import the new QT file back into FCP the image seems to have a slight strobing effect, almost looks as if items are somewhat skipping along every 10 frames or so... Anybody ever get this, or have any setting setups I should have... FCP HD & After Effects 6.5... Thanks..
Jesse G.
You might want to check and be sure you're exporting 24p out of AE. I know 24 FPS is not the default framerate for NTSC video, it could be trying to double frames or something like that.
