egproductions
I have a 6 Pro lights that I use for events. Each one has a router speed control dimmer. They are great lights and look pretty good in my shots, however the issue I'm having with them is that the lamps keep breaking! Some work for 30 hours some work for 2 hours but I they all end up burning out a lot sooner than I would hope. I've tried a couple of different brands (OSRAM and Platinum) but both tend to break. Sometimes the coil separates and sometimes the lamp clouds up and actually burns out. I don't think I am overly aggressive with them either. I typically wind up having to replace 1-2 lamps each wedding I shoot which really adds up. I've marked individual pro lights to see if its one in particular that's causing me issue and I don't think it is. I also don't think it's one dimmer in particular.
My questions:
Any advice would be appreciated. Thanks!
My questions:
- Is it possible the router speed controllers are shortening the lifespan of the lamps? (I've used them on totas and never had a problem)
- Is there a manufacturere of the 250w GCA lamps that last a lot longer than the others?
