Printing to TAPE PROBLEM!?
whizzkid
Hi,
I've done this before with the same equipment I'm using now. I'm trying to print to tape from my laptop and when I hit OK it doesn't show up on the Capture CAMERA. I've changed the video playback option to Firewire and the same for AUDIO. But still nothing happens!
Need Help! Is there anything else I'm missing? is it the deck or my computer? or FCP?
Shane's Stock Answer #8: External Monitor Viewing
If you are working with DV, this is simple. First connect your computer to a camera or deck via firewire, Then connect the camera/deck to your TV/Monitor via RCA or S-Video.
Then start up your camera and tv, then open fcp.
Go to the View Menu, choose > External video > all frames
VIEW>Video playback should be Apple firewire NTSC (If you are using an NTSC set)
VIEW>Audio playback should be Audio follows Video
Techinially, this should send synched video to your TV
If for some reason you can't view your timeline on your external monitor, there are a few things to try:
1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
4) Click in the % box above the image and select FIT TO WINDOW.
5) Go to VIEW->refresh A/V devices
6) Make sure the Log & Capture window is closed
If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section.
