Print to Video using Final Cut Pro 5
arma
I have Sony DV Camera PD 150 and I want to record my final cut project to a Mini DV tape using "Print To Video" on Final Cut Pro 5. I've done this a couple of times before, but now when I hit Print to Video, camera records, but neither video nor audio appear on camera(meaning that my camera doesn't record the project). I've checked system setting and both video and audio are set correctly. Please tell me what to do, I've limited time for this only a couple of hours. Thankssss
Try refreshing the camera. Go to View and click on Refresh A/V Devices. Also, to check and make sure that your camera is receiving the signal, go to View and select External Video. Then select All Frames. If the computer is reading the camera, you'll see the video in the camera.
