Premiere to Speedgrade
847Films
Was wondring if anyone has found a good workflow from Premiere CS6 to Speedgrade. Have tried to using the EDL method but when I sent it over to speedgrade I get a bunch or errors because of all the effects and audio changes. Using the "Send to SpeedGrade" option works but hate how it creates .dpx files and they are huge. Also if I need to make changes to my edit, I have to re render .dpx. I understand Color Correction and Grading are the final stage in post production but there are those last minutes changes. So if anyone has a good workflow please help.
Unfortunately, you've hit the major flaws with using SpeedGrade at the moment. Until Adobe works out some kind of solution that allows us to:
1. See exactly what's in the PP sequence (video, stills, titles, effects, linked comps, etc) in SpeedGrade
2. Properly grade across transitions
3. Make changes back in PP without losing or redoing the grade
...then SpeedGrade just isn't a viable option for most folks.
