Mr.E
Hello all, I've found this forum really informative and hope to learn a lot more and even share whatever little I know with other if the occasion arises.
So, I've shot some footage in with an HV30 that's at (1440 x 1080).
First, workflow within Premiere: I'm working on a TV show and decided to do segments in their own sequence. My reasoning was that I could use a final sequence to putt everything in the order I want. Because I have to use computer screenshots over some footage and plan to do this in After Effects I will be exporting the rough cut of the show to put in AE.
Should I refine the show in premiere before going to AE or does that not really matter?
Should I export each segment on its own, or go with my plan to do everything as one for export?
How should I export from premiere? My final output will be NTSC DVD. I don't know what made me think I could burn HD to a DVD, but I realise I will just have to output as NTSC DV from premiere when I have the final show.
But, how should I export from Premiere to go into AE? H.264 codec gives a much smaller file, but I was told this was more for the web and will cause a loss in quality.
From what I read, I can export as Full 1920 x 1080 as it will use a 1.33 aspect ratio. That's how the HV30 shoots, but you can get the full HD.
Since I am stuck using my not so great laptop, I am thinking it better to do the initial export from Premiere to AE in 720?
Is there anything I should export as anything in particular from AE to use in premiere?
Some background - I'm a student doing my final project, a TV show, and while everyone else has decided to go SD, I was the only brave soul to go HD. It has been a tough journey, but I am determined to make it
I appreciate any help!
