I need to cut some clips and get them to my partner for insertion into a slideshow. How do I cut the clips and put them on a disk as individual clips to insert into a slideshow. I know how to cut clips for a sequence.
I would export each segment separately, but you don't need more than one sequence, and you don't even need to use the razor tool. Just set the first and last frames (Alt + L & R brackets), then (control + m) for export settings, enter the new file's name & format, then either export directly or queue into AME. Tedious to do 75 of them, but it would work fine.
