I've been capturing 24pa footage from an AG-DVX100B into Premiere Pro 2.0 and exporting the output in a variety of formats. I primarily use Premiere to create 24p MPEG2 files which Encore 2.0 easily accepts with no further transcoding necessary (in spite of Encore 2.0 reporting them as 29.976 fps), and creating NTSC DVDs which rely solely on hardware pulldown if necessary.
Having delved recently into Premiere Pro CS3 on the Mac, it appears that when capturing footage, CS3 gives only two capture format options - Quicktime and an "HDV" setting (which is a selectable but apparently unworkable option with my camcorder as the record button is grayed out). No native AVI here obviously.
When following the exact same capture procedure as I do with Premiere Pro 2.0 on the PC, the resulting captured 24pa raw footage with PPro CS3 on the Mac (.mov) shows unacceptable flickering every 4 or so frames. At times, the flickering frames aren't even consistently spaced apart. Tinkering around with the capture settings and frame rate (interpret footage -> uncheck remove pulldown) doesn't help much either, apart from introducing interlaced frames into the video.
I'm not sure if I'm correct in my assumption that the problem can be narrowed to Quicktime 24p capture. When opening the raw .mov file using Quicktime Player and viewing Quicktime Inspector, the reported footage frame rate isn't consistent! I've had source clips reporting frame rates of 29.55 fps, 29.52 fps (??????) and so forth. However, when I open a raw AVI file that was captured using Premiere Pro 2.0 on the PC, the frame rate is reported as a proper 29.97 fps. Importing this PC-captured AVI into Premiere Pro CS3 for Mac works great on a 24p time line. It sure looks like PPro CS3 for Mac is a downgrade from PPro 2.0 on the PC. :undecided
If anyone has an idea or two I could use here (apart from installing Premiere Pro 2.0 to a Fusion or Parallels VM and using it exclusively to capture source videos), I'd really appreciate it.
