L Lazyman New member Mar 30, 2007 #1 Hi: I'm form barcelon, so I shoot in 25p, but I can't find in the new menu a option for a 25p project. There are only 24p options. How can I make a new project in 25p? What about in after effects? Thanks
H Huy Vu Veteran Mar 30, 2007 #2 There should be an NTSC PAL 25fps preset. PAL doesn't differentiate between 50i and 25p so it should be the same preset for both.
jamesh Well-known member Mar 30, 2007 #3 Here's my preset i made for 25p when using footage shot in 25p squeeze mode. It drops directly into my nice widescreen aspect ratio perfectly. editing mode: Desktop timebase: 25.00 frames/second frame size: 720 x 576 (16:9) Pixel aspect ratio: D1/DVPAL Widescreen 16:9 (1.422) fields: No Fields (progressive scan) From memory you just need to set the editing mode to 'Desktop', then it allows you to use the progressive scan fields option. I'm pretty sure this is what you need to get the most from your footage, on my timeline it looks great anyway. hope this helps.
