Premiere Elements Audio Question
Hank E
I have Elements 3.0. and I have an audio editing question.
My question is, how do you add the "points" (for lack of the correct term) on the timeline in order to drag them to change the audio level. I understand you can grab the whole line to change the level. And I have found that if you do a "fade audio in" and a "fade audio out," it will put a "point" at the beginning and end. I then can "grab" those and vary the audio lever, BUT I'd like to add more of these "points" in order to change the level in many different areas in one clip.
Also, if you know the correct term for these "points" I'd appreciate knowing that too.
Thanks in advance.
Hank
