8DFM.com
Just a heads up that Premiere Pro CS3 will now import .mxf files from your p2 cards as I've just downloaded the update and it works!
This is the long awaited update from Adobe's CS3 Production Premium release a few months ago.
You will be able to import the .mxf files along with all of the meta data.
Here is what Adobe says:
"Import and edit content from Panasonic P2 equipment natively, without transcoding or rewrapping. Deliver content quickly and efficiently with true native editing directly from the P2 media. Or copy files to the hard drive to take full advantage of your system’s speed. Adobe Premiere Pro retains key metadata from the P2 media, making it available within the project window. Finally, export your work to P2 to allow playback on P2 equipment."
To get this update please go to the "Adobe Updater" on your system and download the latest update for Adobe Premiere Pro.
This is great news for Premiere users and should eliminate the need for 3rd party software!
Not to mention if you're running OnLocation you can record direct to disk.
